Well, you first have to refurbish the power amp circuits, and then the drivers. You can follow the systematic advice from the 9241, as the circuit is the same, only the total voltage is lower in the 9141.
Since these circuits are a bit critical, I would advise to check all parts, and if in doubt, replace them. If it helps you, I could also send a full set (two drivers, two power amp boards) that are fully done, if you send the faulty ones to me. If you are interested, send me a private message.
Cheers, Michael
p.s.: Also, be advised to check all solder points. I'm working on a 9141 TC myself right now, and this copy has MANY bad solder points ... really many ...
Cheers, Michael
