saba schwarzwald w5
You need:
2 banana plugs 4mm
1 cable with 3.5mm jack
2 resistors 4,7k
Mass you take both channels together to a banana plug.
The two channels each receive a 4.7k resistor and are then grouped together in the other banana plug.
Now you have a stereo mono adapter and can connect it to the TA port.
When connecting several devices, separated by a switch you need a Galvanic isolation.
Available in specialist shops.
Greeting MarkusWenn nichts mehr geht, geht immer noch etwas!!!! -
MRPower schrieb:
You need:
2 banana plugs 4mm
2 resistors 4,7k
Greeting Markus
many thanks
i think use two resistor . stereo to mono
If i can buy one more saba radio. i can use two saba radio W5 by stereo music
