saba transeuropa automatic
      Hi, first I cleaned all keys and pot.s with contack cleaner after I replaced electrolitic capacitors but the radio didn't playing.after I connected two legs of p303 pot. and this radio is playing now my questions;
      1-will I replace this pot.
      2-can I find tis same pot.nowdays
      another problem,the volume pot. was fault and it has 5 legs
      1-what is the that pot.
      2-what is that pot. name
        871,07 kB, 3.024×4.032, 14 mal angesehen
        743,29 kB, 4.032×3.024, 15 mal angesehen
        656,89 kB, 3.024×4.032, 9 mal angesehen
        584,54 kB, 3.024×4.032, 9 mal angesehen
        564,44 kB, 3.024×4.032, 15 mal angesehen
      Hello Inecik,
      the small Pot P303 can be replaced with a similar one of same value. Most dealers should have these parts.
      The other Pot with 5 connections is the volume pot. Exactly fitting new ones will be very hard to find. It is possible to use similar ones with 3 connections, but then the loudness correction will not work: No relative increase of low frequencies when Volume is set to low levels. I would recommend to disassemble it carefully by opening the metal pins. Then it is possible to clean the mid contact clip and the resistor track surface.
      Best regards,
