I am having a problem with my Freiburg WIII and I am hoping to get some sugeestions to solve it. In the attached photos, the 5Kohm resistor marked with yellow is burning up when I use the radio. I tested the circuit and the entire plate voltage for the ECH81 tube is appearing across this resistor. That is too much current ( about 4ma). This problem was intermittant at first but is happening continuously now. The radio will work for a minute or so but eventually the resistor burns up. I am hoping there is not a short in the differential filter. With the resistor disconnected I can measure about 156Kohm resistance at the + connection in the Diff. Filter to chassis ground. Thanks for any advice.
