Greetings: I want to check the FM alignment on my Saba Breisgau 12 ( Same as Meersburg 11). Reading the instructions, it looks like the first step for the FM IF transformers is to adjust the degree of coupling between the primary and secondary. If that is correct, how many turns do I rotate the screw? Do I turn clockwise or counterclockwise for step 1 ( 1. Adjust coupling subcritical with K 501/3) ?
One other question. This radio has the stereo decoder ( Multiplex Adapter 12). I don't have alignment instructions for it but it looks like there is only one variable resistor to adjust on it. What does it do? Thanks for any input. See the photos for more info.
