Hallo !
Sorry but this is almost the limit of my knowledge of the German language !
I'm starting to repair a sick (no, very sick !) SABA 9241 digital. The output and driver (TREIBER) module closer to the power transformer are dead, looks like this thread : Saba 9241 - noch einer zur Überholung. The other channel is OK.
The other problem is the digital display that only displays garbage, like these threads :
Saba 9241 wie Frequenzanzeige Platine ausbauen
Digitalanzeige, RDS etc. beim 9241 und 9260
My questions :
The BD417 and 418 are unobtainium here; even the NTE replacement is no longer available. The only available current production ones I found are these ones from Toshiba :TTA006B,Q (DigiKey 264-TTA006BQ-ND) and TTC011B (DigiKey 264-TTC011BQ-ND). Would these be suitable replacement ? What would you suggest for the BC557B, the BC447, the BC560 and the BSW 39/6 ? Is the circuit very critical or there is some tolerance on the parameters ? For the output amplifier, I was able to purchase the BD245C and BD246C from BG electronics but they are not of the same brand (Bourns for the 245 and Power Integration for the 246) When I was a young student in electronics school I leaned that a complementary pair should be of the same brand, so should I hunt to get same brand or again the circuit is not that critical ? I have access to a well equipped lab, so I can match parameters if required, as long as I know what I should be looking for !
For the display, can I replace both the AO808 and AO810 display drivers using this technique :
Danke !
Claude
My questions :
Danke !
Claude
