Hello everyone
I'm here to bother you again. When I turn off the machine, the FM meter reads fine. After turning it on, I tuned it. The pointer only swings in the red triangle area and does not swing to the left. When the correct signal is adjusted, it only indicates the green position. It seems that the indicated frequency is not very accurate. Please give me some advice. Some repair suggestions, thank you very much!
