Hi,
I repair lots of Saba automatic radios in Canada.
Today, I am struggling to revive a Saba FM Multiplex Adapter 12, and have an issue with the coil L5 (doubler 19->38 kHz).
The doubler works, but after some minutes the 38 kHz voltage drops significantly. If I cool the coil (with cool spray) the voltage is back up again…(supply voltage is correct and stable, the 19 kHz voltage at the oscillator coil is perfectly stable).
Therefore I conclude that the coil L5 is faulty (insulation failure when it heats?).
Does anyone have an idea of the specifications of this coil (listed in Saba documentation as part 3872 507 111)?
If I could get hold of its specs, I could perhaps have a replacement made (by Reinhöfer, for instance)…
Of course, a spare, or an adapter out of service (but with this coil OK) would also solve the problem
Thank you in advance for yout insights!
...Thank you in advance for yout insights!
