Replacement feet for SABA 9141 tc
      Hello to all members.
      I finally found replacement feet for my 9141 tc that fit and stay in place perfectly. It is an Essentra product, part number FF-006-P5X6.5B. I purchased mine from DigiKey, the stock number is RPC3964-ND. It is also available from Mouser as part number 144-FF-006-P5X6.5B.
      Regards,
      Claude VA2 HDD
        120,47 kB, 2.159×1.358, 7 mal angesehen
        194,58 kB, 1.576×2.762, 7 mal angesehen
        283,78 kB, 3.925×933, 7 mal angesehen
        262,25 kB, 3.468×1.751, 7 mal angesehen
      Also, ich habe beim 9141 (und auch beim 9140) bisher einfach immer selbstklebende Filzfüße genommen. Weil das Gehäuse ja auf zwei Leisten steht, geht das recht gut, und mehr Abstand zur Grundfläche braucht man eigentlich nicht. Da der Kühlkörper ja aussen ist, reicht die normale Zirkulation der Luft ansonsten aus.
      Claude, you are absolutely right -- and I have used such feet in the past, too. Most of them, however, leave traces or marks on furniture, which is sometimes a problem. This is why I changed to self-adhesive felt feet (not plastic). They come in all sorts of sizes. I use solid ones with about 20 mm diameter and 5 mm height. No scratches, no traces, and a good decoupling of any (small) vibration, too.
      Cheers,
    • Benutzer online 1
