MMOEXP Dune: Awakening:​Dune: Awakening — Hagga Basin Exploration Guide
      Hagga Basin is your first real sandbox on Arrakis: a sprawling 65 km² PvE‑focused zone where survival, exploration, and building come together. It’s the ideal place to learn the systems of Dune: Awakening — from crafting basic gear to founding your first base — and a stepping‑stone to deeper challenges in the Deep Desert.
      Getting Oriented
      Hagga Basin is subdivided into multiple named subregions like Hagga Basin South, Vermillius Gap, Sheol, and Shield Wall — each with distinct terrain and resource opportunities. The official world map shows that Hagga Basin has 12 distinct entry points, so where you fast travel in matters: entering from the north will drop you in the northern reaches (often rockier and safer), while a southern entry might leave you on open sand with sandworms nearby.
      Using the in‑game world map (press M) is key — you can track destinations, see elevation changes, and choose better routes through the Basin’s varied terrain.
      Survival & Travel Tips
      Survey the Land: Deploying Survey Probes reveals unseen map areas and resource nodes; essential before committing to long treks.
      Fast Travel Smart: Instead of spending Solari, leave Hagga Basin and re‑enter at a specific entry to reposition quickly within the Basin.
      Watch the Terrain: Hagga Basin has hazards like drum sand and narrow storm corridors, which sap shields and lure worms — so build your base on solid rock and plan paths around risky zones.
      Base Building & Long‑Term Plans
      As the main PvE region, Hagga Basin is where you’ll construct your first permanent base. Building here is safe from weekly wipes (unlike the Deep Desert), so secure a spot near vendors, resource routes, and elevation to reduce worm risks.
      Key early base considerations:
      Place on bedrock near supply routes.
      Avoid open dunes and storm corridors that harass vehicles, drains shields, and expose structures to danger.
      Keep your shield generator fueled and taxes paid to prevent decay.
      Points of Interest & Resources
      Hagga Basin contains vital landmarks like shipwrecks (rich loot but risky), Imperial Testing Stations, and rich resource nodes for early building materials. Use the flow of quests to lead you to Trade Outposts and hubs like Griffin’s Reach, which provide access to the wider world and fast‑travel options.
      Final Tips
      Exploration here is about planning and preparation. Take your time learning each sector, avoid deadly zones until you’re ready, and use the Basin as your safe foundation before venturing deeper into the harsh deserts of Arrakis.
      Edit Admin: Links aus Spam entfernt
