Good evening everyone,
here the photo of the repair of the power supply of Saba 9941. The great bridge rectifier is 100v/10a type and was coupled with the cooling radiator. The capacitors are large 10.000MF/63V protected by silicone hat. The fuse holders are protected in plastic case. The capacitor 220Mf is 100v, as recommended to me. Resistance 2.2 ohms is the type fused integrated. The bridge rectifier square D in 1427 was replaced as recommende to me: I was able to find the same square type, but 1.5 Amp type. The bridge D1414 is placed between the two fuses ( 2 amp ), using " sterling " tube to prevent short circuits. All voltages are correct . The ripple voltage of + -35 volts is 5% for 5 Amp absorption: very good! Now we have to see what happens when we turn-on the machine! Greetings to all, see you soon. Giuseppe.
 with good tantalum capacitors. The tantalum capacitors have excellent low-noise characteristics during the charge and discharge, and good heat resistance, also their value remains stable over time. Their use is designed on the lines of very small signal.  I have calculated that the value of the capacitors in the signal path in this controller  board is a good right size, then I will confirm the same values chosen originally. In these days of continuous reading of the wiring diagram, during my train journey to the place of work / home, I have to confirm what has already been said by all of you: the SABA UHC 9940/41 is just an electronic honest hifi compact and well done. Here is a photo of the two capacitor discharges, soon I will make a picture of the board with all the capacitors replaced with the tantalum  type. See you soon ! Giuseppe Mazzilli
